Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 9N Parts Online
Re: 9n won't charge, did they ever?
K. Thomas
05-11-2013 10:16:20
Today I removed the two wires from electronic voltage regulator since the amp gauges still were not showing a charge (one gauge at rear of generator and one gauge in console). For an instant I started tractor and touched the two wires together that were on each side of regulator. I immediately showed 30 amps right after starting the tractor. I turned screw on generator to see if I could reduce the 30 amps but it didn"t, but just would then go to zero if I went to far. What do we conclude guys based upon this info? I do have a new tiawain voltage cutout I could install next. Thanks, Kurt
K. thomas
05-11-2013 11:53:37
 Re: 9n won't charge, did they ever? in reply to K. Thomas, 05-11-2013 10:16:20
I removed the electronic regulator and put the new cutout on. Before starting the tractor, I polarized the cutout between it"s terminal. Seemed like I heard a click and there was a little spark. Started up the tractor and amp gauges read zero. I am letting it run for a while to see if the voltage increases on the battery. Currently it"s at 6.2 volts. I"m at a loss at this point on getting the gauge to read a charge. Kurt
K. Thomas
05-12-2013 05:39:43
 Re: 9n won't charge, did they ever? in reply to K. thomas, 05-11-2013 11:53:37
Well will need to give up on it for now. We"re in the mowing season and I"ll have to just keep charging the battery. In the past month it all hasn"t gone bad, I"ve replaced points, plugs, cap, rotor, condensor, spark plug wires, amp gauge, new steering wheel, cleaned air cleaner, changed hydraulic oil,rewired and installed new light switch and lights work & have ordered 1-3/8 pto conversion not here yet, removed 8v battery and put new 6volt in. Starts and runs great, just no charge. Thanks to anyone that has tried to help me.
