Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: the old bitceeee tractor is crazy
old
05-11-2013 08:31:28
Do you have a good steady flow of gas out of the carb drain plug?? If you do not know for sure pull the drain plug and let it flow for say 3 minutes. If it slows dawn then work you way back till you find where it is clogged up
it me again
05-11-2013 11:17:52
 Re: the old bitceeee tractor is crazy in reply to old, 05-11-2013 08:31:28
11 min to drain the 5 gal of gas but it now back doing same thing she beinn a bitceeeeee season again..
old
05-11-2013 18:32:09
 Re: the old bitceeee tractor is crazy in reply to it me again, 05-11-2013 11:17:52
Is that out the drain plug on the bottom od the carb or the line??
it me again
05-12-2013 05:21:02
 Re: the old bitceeee tractor is crazy in reply to old, 05-11-2013 18:32:09
it come out drain plug pretty fast too there no slow down when coming out the fuel line..
old
05-12-2013 08:20:21
 Re: the old bitceeee tractor is crazy in reply to it me again, 05-12-2013 05:21:02
Ok try this. Start it up and while running try to loosen the main jet adjustment screw. If you can loosen it to the point you can remove it from the carb then you have a jet clogged in the carb some place. Did that yesterday on a 9N and today I will be putting it in the soup to soak for a couple days then rebuild it after I find a new float for it
