Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Amp draw on tractor?
05-10-2013 19:44:12
41 9n 12V. Tractor has not ran for about 2 weeks now. Had gas leaking from carb so I put repair kit in carb. Changed plugs, plug wires, points, condenser and still would not start. Had fuel from bowl to carb and thru carb. took carb off and shot ether up intake and still would not fire. I am think coil is bad because everything else is new.
36 coupe
05-11-2013 04:32:28
 Re: Amp draw on tractor? in reply to Dave/MO, 05-10-2013 19:44:12
Never could afford to change parts.On gas leak a bit of dirt can make a carb flood.My tractor floods now and then.It sounds like you are using your ohmmeter on circuits with power in them.That WILL cook your meter.Your new points and condenser may be junk.Old ones good quality.
05-10-2013 20:49:36
Check for spark with a plug grounded to the block. Should jump at least 3/16" with a blue white spark. I asked before where you are located in MO.
05-10-2013 21:10:18
 Re: Amp draw on tractor? in reply to HCooke, 05-10-2013 20:49:36
I live in Silex. About 10 miles north of Troy
