TractorLinks.com
Show Parts for Model:
Re: Fuel sender hook up pic is this right?
JMOR
05-08-2013 07:19:13
Quoting Removed, click Modern View to seeCondenser voltage in this instance is a "don't care". Yes, as on points will be fine. Do go ahead & put that ground wire on one of the 6 mounting screws over to good chassis ground (the wire everybody has been telling you about). Condenser........other than possible radio static when gas sloshed around, you can cut the condenser & never know it was there or absent.
Britcheflee
05-08-2013 08:49:24
 Re: Fuel sender hook up pic is this right? in reply to JMOR, 05-08-2013 07:19:13
I have the original AM Radio in it - hardly worth putting on as it is tough to get any stations and the sound is poor so will remove the condenser. Will re-locate the grounding wire. Tks
JMOR
05-08-2013 10:07:12
 Re: Fuel sender hook up pic is this right? in reply to Britcheflee, 05-08-2013 08:49:24
Quoting Removed, click Modern View to seeWhat do you mean by "relocate the grounding wire"? So far as I can tell there is no grounding wire to "re-locate". Do you mean, that you will install a grounding wire? Just trying to be clear.
