Identify tractor
Hi is there anybody that can help me identify a tractor I just purchased.I think it is a 1950.It has a side dist.There is no serial # on the left side but there is a identification plate on the right rear side that reads.Ford industrial engine serial #1192-G2-CB/ Type 4-2510.Any help would be appreciated.Thanks
(quoted from post at 08:03:37 05/08/13) Hi is there anybody that can help me identify a tractor I just purchased.I think it is a 1950.It has a side dist.There is no serial # on the left side but there is a identification plate on the right rear side that reads.Ford industrial engine serial #1192-G2-CB/ Type 4-2510.Any help would be appreciated.Thanks
Without pictures it will be hard to impossible to tell. it could be 9n or 2n or 8n. I have what I "think" is 52 with an industrial engine in it. look for casing codes on the rear axle. that may help. I have seen no records of industrial engine serial numbers.
good luck.
I am not an expert and not trying to be but an 8n has a 4spd trans.and both brake pedals on the right side 2n 9n have a 3 spd trans and pedals on oposite sides 2n and 9n don,t have the little lever under the seat on the right side.of course it can be mix and match as well.hope that helps.
deffinately post a pic and check things like axle casting dates.
with a replacement engine and no oem sn which was on the oem engine.... could be 39-52 N..e tc.
(quoted from post at 16:45:26 05/07/13) I am not an expert and not trying to be but an 8n has a 4spd trans.and both brake pedals on the right side 2n 9n have a 3 spd trans and pedals on oposite sides 2n and 9n don,t have the little lever under the seat on the right side.of course it can be mix and match as well.hope that helps.
Flembo, throwing you a curve, but I have a 47, 2n (3 speed trans) with clutch on left and both brakes on right side. It looks factory. It had this setup when I bought it. I think there was an after market setup at sometime not sure.
trouttman
Thanks.Was hopeing somebody new where u could find serial #s for the industrial engine.The one I just bought has both brake pedals on the rt side/ the little lever rt side under the seat/amp& oil pressure gauge&3 speed trans/with side distributor.What kind of fuel is ok to run in this motor.Does anybody add lead additive?Thanks
