TractorLinks.com
Order Ford 8N Parts Online
Re: 8n miss
soundguy
05-07-2013 16:46:39
clip under the rotor in place and rotor fit tight and not move?
advance mechanism in good order?
Tim23
05-07-2013 17:04:40
 Re: 8n miss in reply to soundguy, 05-07-2013 16:46:39
The rotor seems to fit tight, I'm not sure about a clip. The springs on the weights are a little light, but everything moves freely.
soundguy
05-07-2013 17:17:06
 Re: 8n miss in reply to Tim23, 05-07-2013 17:04:40
how about the dizzy shaft itself.. much play?
Tim23
05-07-2013 17:31:39
 Re: 8n miss in reply to soundguy, 05-07-2013 17:17:06
I can turn it back a forth a little. I"m at work so I"m having to go off of memory. It seemed like it turned more than I thought it should, but not enough to knock it out of time by more than a degree or two. You can wobble the shaft side to side, appling force to the cam, but not by very much and it doesn"t seem like it wants to move. I"m not sure if there is enough play to be causing my problems or not.
