OT: 2003 Dodge Durango 4WD Transfer Case
Danny in CO
I just finished replacing the transfer case on my 2003 Durango. The old case was cracked and all the fluid leaked out. The Service 4WD light now comes on. I think I forgot to connect a ground connection to one of the bolts for the case. I believe the issue is only an electrical issue and not mechanical. It seems to drive fine, I just don"t have 4WD.
I assume it is OK to drive it like this. Am I correct? Any opinions?
Thanks,
Danny
PS: It is an electrical switch 4wd with the switch on the dash.
"PS: It is an electrical switch 4wd with the switch on the dash."
Yep, but that switch just initiates the process.
The powertrain 'puter then looks at lots of stuff, likely front and rear wheel speed, front and rear driveshaft speed, vehicle speed, temperature, engine load, what the ABS or traction control system is doing, etc., etc., etc., before deciding if the shift into 4X4 you asked for is actually going to happen.
Unless you see something obvious wrong (like you wondered, ground wire disconnected), you are gonna need a scan tool to see what is irritating the 'puter into turning the MIL lite on and refusing to complete the shift.
MIGHT not hurt to drive it, but I would check for the loose wire, then scan it if necessary and fix it BEFORE putting miles on it.
LOTS of $$$$$ possibly involved if the choice to drive it is not a good one!
