My question is: what is the most common sleeve retainer to use when replacing the sleeves. I have read so many stories that i am totally confused on it.
So, I need somebody that has done this before and knows what they are doing to tell me what is best. I understand that you are supposed to coat the bottom 1/3 of the cylinder wall with it. So how much really stays on the wall as you drive the sleeve in? Seems to me it would just scrape it off as the sleeve goes down?
Also, i was told that Loctite Threadlocker is the same stuff as sleeve retainer, is that true??
