Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: electronic ignition conversion
NOXJohn
05-06-2013 10:45:33
Is it worth the money? Most likely not. However, the Ford N tractor front mount distributor is getting to be a rare beast. Good points, rotor, cap, 6 volt regulators and 6 volt batteries are getting harder to find. If your tractor is running good or only needs points then get a set of Blue Streak points. You should be good for years. If you have 6 volt generator/regulator problems and need to replace some parts you may wish to consider converting to a 12 volt alternator. It will cost a little more but replacement parts and batteries are available at any car parts store. If your tractor has a 12 volt system and you have some extra money EI works great. I have converted all three of my 8 N's to 12 volts. One of my 1949 8N front mounts has EI. All start great. All run great except the EI runs a little smoother. I have purchased three tractors when I only need one. I have rebuilt all three at a cost of $3K+ each. It is a hobby not a business. None of the expenditures I have made on my Ford 8 N hobby was worth it in terms what I could get back if I sold any of them. Its your money and your tractor. Spend your money the way you want and do whatever you want with your tractor. Have some fun. Its a hobby.
Copyright © 1997-2015 Yesterday's Tractor Co.
