TractorLinks.com
Show Parts for Model:
Re: Can I test fuel sender unit on my 53 Merc?
Texas!
05-05-2013 08:52:09
I don"t know about 1953 but on my 1958 F600 if I remove the wire to the sending unit and connect it directly to ground (12V Neg ground electrical system) the gauge goes to Full.
frrankmn
05-05-2013 09:09:45
 Re: Can I test fuel sender unit on my 53 Merc? in reply to Texas!, 05-05-2013 08:52:09
I believe the float arm is attached to a variable resistor. If you take it out and check it with your ohm meter you may find the problem area on the resistor. You may not be able to fix it but it will be educational.
Britcheflee
05-05-2013 10:20:58
 Re: Can I test fuel sender unit on my 53 Merc? in reply to frrankmn, 05-05-2013 09:09:45
OK thanks - the gauge goes up and down randomly even when at rest so the fuel is not sloshing around - thankfully it looks like a pretty simple job to remove and, for once easy access through a top plate you lift up.
Have to double check I have the battery disconnected before I mess with that!!!!
Lee
