Waterworth Farm
I have had my 9n about a month and a half now. I have ran about 3 tanks of gas through it. Every time I am getting low on fuel, it starts acting up, i.e. running a little funny, hard to start, so on.
The first time that it did it I rebuilt the carb and cleaned the fuel line. I found sediment in the bowl, so I removed the fuel shut off valve and found a bunch of dirt and crud in the valve. When the tank drained there was a bunch of dirt and stuff in the gas that came out.
When I put everything back together everything worked great until about the end of my next tank of gas. I have done this three times now thinking that it will eventually clean all the old crud out.
Is this the only way to clean it out? Or, is there something else that I should know?
