toddbmobile
I have a Ford 8n that has been converted to 12 volt. I have a 12 volt coil with an inline ballast resistor. The ballast resistor is inline to wire to top of coil. I have a one wire alternator. I have a jumper from port 2 to the battery post on the alternator from there to solenoid. What was working now is not. My battery is not charging. Please any ideas will be much appreciated. I took my alternator to an alternator place and they said it was fine, but recently I fried my coil due to bad ballast resistor. Please see my attached album on my connection and setup. If I charge my battery with my battery charger tractor cranks right up and runs fine till battery dies from cranking.
photos below of my setup.
https://plus.google.com/photos/1143...799396865751073?authkey=Gv1sRgCNeL_7ixipfazAE
