Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: How to remove front wheel
05-04-2013 14:00:45
ditto what old said.
can also bang on it with a hammer and block of wood.
note.. if this is a single wheel trike from an 01 series.... hub's coming off. ;)
05-04-2013 17:59:06
 Re: How to remove front wheel in reply to soundguy, 05-04-2013 14:00:45
Thanks for your reply - I have a 1950 8n - don't know what "a single wheel trike from an 01 series" is or why the 'hub's coming off". Can you explain further?
I did not think the hub had to come off, but the rim is really stuck - been banging on it - If I could get the tractor started I would try the driving it around method. Guess I'll need to get it started first, then work on the tire.
05-04-2013 18:39:03
 Re: How to remove front wheel in reply to PeteDeLorme, 05-04-2013 17:59:06
since you have a 50 8n.. and not a 1 wheeled trike from an 01 series.. then you won't have to take the hub off.. so why explain?
if you have the lug nuts off.. and have doused the back side of the hub where it meets the rim with oil.. then just keep working it with a hammer and block of wood.
alternately.. if you have an air hammer.. it will liekly buzz it right off with a blunt tip.
buzz around the area where the lugnutz are.. that is where it is stuck..
