TractorLinks.com
Order Ford 8N Parts Online
Re: 8N Sleeve problem.
Ken(Ark)
05-04-2013 05:58:49
Just speculating ,
If the bore was worn say .010 and someone honed it .005 and re rung it then it would run (poorly) . Hasting Ring manufacturer claims their rings will seal a .012 tapered bore .
The excess blow by probably overheated the sleeves allowing them to move which could have worn the block a little also .
A piston skirt and the lands between the rings are the nominal size for the piston , the top land is smaller for heat expansion . You can usually see the rings on a fresh rebuild if the piston is tdc and you look close .
I would bet the ring gap on the remaining 3 pistons is .040+
Add it all up and you would see a big gap .
TheOldHokie
05-04-2013 06:49:38
 Re: 8N Sleeve problem. in reply to Ken(Ark), 05-04-2013 05:58:49
He can measure the bore on the sleeveless hole with a ruler. It doesn't have to be accurate to a thou - pretty easy to discrimate 3.267 from 3.367. At that point better advice can be provided.
TOH
