TractorLinks.com
Order Ford 8N Parts Online
Re: 8N Sleeve problem.
Charner
05-03-2013 20:37:46
I would guess that the engine was knocking sounding as a loose rod bearing. This would have been the sleeve going up and down. The retainer ring on top of the sleeve was hitting the top of the cylinder bore. The metal failed and the retainer ring broke off and the sleeve was pushed into the crank case and destroyed by the crank shaft. Thus the metal peices of the sleeve. The motor still will run with much less copression on that cylinder. Why so much of a gap in the piston/sleeve is unknown. You must match the block, sleeve and piston for proper repair. This time, I would be very liberal with a sleeve retainer solution when installing them.
