Looks like more bad news for sir 8N with loose sleeves.
Took number one piston out today and it looks like the rod is from a 9N as it says so on it. It also has the word "canada" stamped on it.
I have no idea what that means, so maybe someone out there has an answer. It has a psrt number on it but by the time i nade it to the house from the barn, i done forgot it so will copy it down tomorrow.
Second the rod bearing was worn some and had scratches in it in rotation fashion which is not real bad, i guess. No wear thru to the copper yet.
The bad thing, I think, is the bearing has .060 stamped on the back side of it.
Again, i am not real sure what that means but i am sure someone out there does.
The piston looks new except for the top which has a burnt oil scale on it from the rings allowing oil to the chamber.
Wrist pin is tight, and rings look new as well.
Thanks for your help.
