TractorLinks.com
Show Parts for Model:
Re: Would you try to save this rust
Dukester
05-03-2013 14:21:02
Would be good if I had a neighbor welder but I'm adding up the metal and rods and cost welder might charge and it's getting up there, never mind the time cutting out the old...how did you do that by the way??..
Ken(Ark)
05-03-2013 18:12:07
 Re: Would you try to save this rust in reply to Dukester, 05-03-2013 14:21:02
The welding part would not be that bad , it's the cut out and prep time that will burn up time .
If you can replace a battery or change your own oil you can probably wire weld !
If you can get a buddy to help set up the welder for the first time and give you pointers for two minutes I would bet you could finish it .
mbramble
05-03-2013 16:44:37
Yes, the welder neighbor was quite a help!! I used an el cheapo Harfor Freight 4 1/2" angle grider and cutoff wheels for the most part. The oxy acetylene setup I now have would have made it MUCH easier!!
tracman
05-03-2013 14:41:46
If you could scare up some metal maybe from a scrap yard or auto wrecker, you could bolt it on. That may not be as pretty but it would work.
