8N water pump replacement
tracman
With the new water pump is there a way we can check to make sure the fan doesn't come flying off like it did on Bruce?
If it is installed correctly and is a good pump and every thing is tighten up like it should be that is about all that can be done. If the pump is bad or defective then there is nothing short of leaving the radiator off and test run it for a minute or so and even then it could be unsafe to do because if the fan flies off you might be what it plays catch with and that could be deadly
is shaft wobbles. bearing is loose. if bbg is loose.. seal will wear.. if seal wears.. water eats bearing. once bearing goes.. fan flies thru rad, and money flies out yer wallet.
every time I check my oil befor starting i tug on a fan blade.. protects my wallet.
