TractorLinks.com
Show Parts for Model:
Re: OT chev won't start
delvaughn
05-03-2013 11:19:42
YAHOO!! The car started!! It had a bad connection were the wiring harness that comes from the engine compartment to the inside wiring harness of the car connect.
I did what ASFguy said an put a jumper wire from #87 to #30 on the relay an while I was moving the harness inside the car the test light came on.
I than just bypass the connector with a short wire an it started. Without ASFguy an Bob's help I wouldn't have known how to do the jumper trick.
Now I have to change the head gasket. For about a year I have had to add water about once a month. But it has gotten to be every week now. After it sets it will run bad until the water gets out of the cyl than it runs good. It is starting to cut out some going down the road now.
THANKS VERY VERY MUCH FOR THE HELP!
ASEguy
05-04-2013 04:23:28
 Re: OT chev won't start in reply to delvaughn, 05-03-2013 11:19:42
Glad it worked out for you.
