TractorLinks.com
Order Ford 8N Parts Online
Re: 8N Sleeve problem.
hotdawg22
05-03-2013 08:43:38
The other three sleeves just started coming up as i turned the motor by hand, so i just pulled them out leaving the pistons in, for now. I will pull the pistons today and inspect the entire block for other damage.
So the gap between the piston and the sleeve is a mystery// just how did that large of a clearance happen? You are right, it doesn't matter which sleeve is used the piston size remains the same.
JMOR
05-03-2013 08:53:21
 Re: 8N Sleeve problem. in reply to hotdawg22, 05-03-2013 08:43:38
"Mystery" is a good word, here, or a bad estimate of fractional inches? Looking at the numbers, if used 0.040 sleeves, then the inside of the sleeve would need to be completely worn away plus eat into the block by another (0.125-0.0400x2) = 0.045 inch in order to achieve your 1/8 inch piston to wall clearance!
TheOldHokie
05-03-2013 09:14:53
 Re: 8N Sleeve problem. in reply to JMOR, 05-03-2013 08:53:21
JMOR said: (quoted from post at 11:53:21 05/03/13) "Mystery" is a good word, here, or a bad estimate of fractional inches? Looking at the numbers, if used 0.040 sleeves, then the inside of the sleeve would need to be completely worn away plus eat into the block by another (0.125-0.0400x2) = 0.045 inch in order to achieve your 1/8 inch piston to wall clearance!
My experience says EVERY N-series engine is a mystery until it is opened up and measured :roll:
Now that I am properly attired I will suggest that they do sell a .083 overbore kit to replace the .090 wall sleeves. The piston bore on them is 2.270. So if someone installed stock pistons in an engine that previously had the oversize pistons in it you would be getting close to that .125. But my trusty assistant Watson cautions that there are many other possibilites as well....
TOH
This post was edited by TheOldHokie at 09:15:51 05/03/13.
teddy52food
05-03-2013 10:31:07
 Re: 8N Sleeve problem. in reply to TheOldHokie, 05-03-2013 09:14:53
Should be .040 not .090.
