TractorLinks.com
Show Parts for Model:
Re: 51 ford ol blue bi---h back again
old
05-03-2013 08:36:37
What does the spark look like?? It may well not be a carb problem but weak or intermittent spark. A bad ignition switch will do that as will a bad condenser or loose wire some place. I would try a hot wire from the battery to the coil and see if that helps or does nothing. Make sure you have a good blue white spark that jump a 1/4 inch gap. Also when was the last time you serviced the air cleaner been. Ya it could be a carb problem and the carb may need rebuilt or re done if you have done it in the last few weeks because it is easy to miss some thing
