Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: electric brakes
Kurt-NEPA
04-30-2013 07:36:17
Lost the brakes on my travel trailers many - many times. Got to be a real PITA. Every time it was corrosion. Usually at the connector, but almost as often it was a ground connection.
Time to get the multi-meter out and start probing.
If it were me, I would do some trouble shooting with a jumper wire between the magnet ground and the battery negative. At least that eliminates the ground as a source of the problem. I'm not sure how your magnets are grounded - sometimes you have to pull the drum. Hope that's not the case. If it is, just attach the ground wire to a clean spot on backing plate or axle.
Hope you find it easily.
