Tom Bowman
Dell: I read your archived post about the "20/20" Brush/Roller Paint Job, which I plan to do on my Fergy TO-20.
I don"t have the facilities, equipment, ability or desire to spray with automotive paint, as I don"t need that kind of end result for a Workin" Tractor.
Question(s): 1. For the rolled paint on the sheet metal, do you figure on just one coat? Same for brush on castings?
2. Do you prime over old, but sound paint on sheet metal/castings, or just areas that are down to bare metal after sanding/cleaning?
Can you use brushed/rolled primer, too? Does it need to be sanded, before applying the topcoat?
3. I know your instructions call for acrylic automotive enamel, but I"m planning to use VanSickle alkyd enamel, with hardener, mainly because they have the Ferguson color in stock at my local farm supply store.
Thanks.
Thanks.
