TractorLinks.com
Show Parts for Model:
Re: Help getting pump back in?
Hobo,NC
04-30-2013 04:42:06
You don't have to pull the chambers off to clean up the valves... One thing to look for is were the valves seat in the chambers on parts tractors that have set awhile the valve seats rust I have seen my share of this...
If you have to play I use CNH chamber gaskets as from time to time issues arise from other gaskets that you don't need...
The lift cover does not have to come off,,, jack the tractor up so you can lay under it and install the pump no jack needed... You have already tore it up from misinformation from folks that claim they know but forgot it are in a race to see who can have the highest post count..
gwstang
04-30-2013 19:06:54
 Re: Help getting pump back in? in reply to Hobo,NC, 04-30-2013 04:42:06
I do have the N jacked up and just left it with some heavy blocks under the rear rubber to sit on. Sounds like it shouldn't be any harder to install than to take out the old one. I'll check the valves/springs and if those are rusted or broken, I will take the ones out of mine to install. thanks.
