8N Tranny Oil
Pete-IN
Location
Waterloo, IN
Posting this for a friend. He bought an 8N and got owner manual with it. He would like to know what oil/grease goes in: Transmission; Hydraulics; Differential.
He said the owner book only gives a Ford part number. Thank you in advance.
They are all one common sump on an 8N.
UTF that meets Ford spec M2C134C/D
Some of the Traveller UTF's from TSC for example, it's listed on the can.
Holds a little less than 5 gallons if it hasn't had the sludge cleaned out lately.
Edit - I should have said the specifications the fluid meets are listed on
the can, including the Ford spec if it meets that spec.
Any good universal hydraulic/transmission (Hy/Trans) fluid that meets Ford134 spec. One common sump, original was 90W mineral oil.
Lots here like Traveller brand.
as said. utf meeting m2c134 spec.. or a gl1/3 90 wt mineral gear oil.. or a gl4/5 gear oil meeting the mt1 spec and /or stating yellow metal safe.
