TractorLinks.com
Order Ford 8N Parts Online
Re: 1951 8N Generator or Alternator
jboyer1028
04-23-2013 09:55:31
Thank you for the responses. It is very helpful. My 8N is 6 volt and positive ground so sounds like it is a generator. 6 volt batteries aren't cheap either.
Jeff
old
04-23-2013 11:56:07
 Re: 1951 8N Generator or Alternator in reply to jboyer1028, 04-23-2013 09:55:31
6 volts and + ground say it is 6 volts no matter what . If you hook up an alternator + ground you will let the smoke out the moment you hook up the battery
soundguy
04-23-2013 10:37:26
try polarizing the genny.
key off.
jump bat hot to armature.
then check to see if she is charging. IE.. look at meter, and check across batttery when running.
if no charge.... do a motor test.
shut mahcine off.. slip belt off jump bat hot to arm and then ground field.
genny SHOULD spin.. if it spins.. it SHOULD charge.
if it does.. then put belt back on and start up.. if no charge.. jumper field to ground. if it charges.. get a new reg.
if still no charge.. keep field grounded, and then jump arm to bat.. if charge occurs, get a nvew reg..
