2N Governor
I just found out that parts for the Novi governor on my 2N are no longer available. Does anyone know of a good source for a used, working governor?
You might check with forum members John Smith or Jim.UT, both sell good used parts.
John Smith here: John's Site
Jim can be reached at WebbTractor at gmail.com
Where are you located? I have one here in Michigan as well.
I have not tested this one, but if you're close you can try it out.
I wouldn't want to sell it as good not knowing for sure.
Thanks for the info. I'm in NC, so it'd be a bit of a haul to MI try out the governor. I appreciate the offer, though.
I'll try to get in contact with the folks you listed. Thanks again for the help.
In addition to the folks that Royce mentioned, you
might check with Dereck at Just 8nS. They are
located in NC.They have some used parts and I
believe Dereck rebuilds governers.
