Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 9N Parts Online
Re: 9N Tranny Problems
Cattrell
04-22-2013 11:00:36
So is a new shift lever the fix???
Thanks for the help
soundguy
04-23-2013 07:02:35
 Re: 9N Tranny Problems in reply to Cattrell, 04-22-2013 11:00:36
in addition to what jock said.. check the pattern under the cover too.
Jock(OR)
04-23-2013 12:17:55
 Re: 9N Tranny Problems in reply to soundguy, 04-23-2013 07:02:35
9N and 2N don't have the plate under the cover, only the 8N.
soundguy
04-23-2013 15:06:23
 Re: 9N Tranny Problems in reply to Jock(OR), 04-23-2013 12:17:55
good catch :)
Jock(OR)
04-23-2013 02:19:32
I think that one could fix this by removing the shift lever and building up the spherical area that contacts the shift rails with weld and regrinding it spherical again. I know this was done commonly by Model A Ford restorers back in the day.
You would have to look closely at the shift rail slots as well. If they are worn they may need to be built up.
As I mentioned earlier, paying attention to your shift will avoid this lockup while you prepare yourself for the permanent fix. It is a lot of work to remove the transmission top cover!
Copyright © 1997-2015 Yesterday's Tractor Co.
