TractorLinks.com
Show Parts for Model:
Re: carburetor leak again
Eriklane
04-20-2013 06:11:57
Where is it leaking? Mine had a slight tear in the main large gasket. Replaced that and the problem went away.
teddy52food
04-20-2013 07:24:12
 Re: carburetor leak again in reply to Eriklane, 04-20-2013 06:11:57
Gas level is way below that gasket. You had other problems like a spec of dirt holding the needle open that corrected itself when you took it apart.
GB in MT.
04-20-2013 07:39:59
 Re: carburetor leak again in reply to teddy52food, 04-20-2013 07:24:12
BINGO, Teddy;
Right on the money, with this!!!!
AND/OR....other causes of flooding carb......:
Leaking floats, filling with fuel, holding floats down to bottom of bowl
Floats not being correctly adjusted.
Floats rubbing on bowl sides, holding them down, float needle open.
Float needle, seat gasket, not tight and letting fuel flow past the seat.
AND ON & ON,.....ect, ect!!!!!!!
GB
