Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: fuse confusion
tracman
04-18-2013 12:01:14
Dell can you pull the connector off the pump and repeat the fuz /lite check?
8N-Bob
04-18-2013 12:56:48
 Re: fuse confusion in reply to tracman, 04-18-2013 12:01:14
Sounds like a bleeding ground to me also.
Unplug the pump and with out the fuse see if there is voltage on both sides. If yes start pulling other fuses and when the voltage is gone you know what circut you have a bad ground in. Also is the fuel level sending unit on the same circuit that could be your problem there also.
Lots of Luck
Bob
Copyright © 1997-2015 Yesterday's Tractor Co.
