Show Parts for Model:
Re: fuse confusion
04-18-2013 10:43:38
Problem may be up stream from the fuse block.
Maybe enough power to turn on your test lite but not enough to run the fuel pump. This could drain your voltage down so much it won't turn on your test light when your pump is connected to the circuit.
I would try a test lead from the battery to the fuse on the end before the pump so it will be fused if there is a short circuit. hth WaltMo
Roger in Iowa
04-18-2013 10:47:16
 Re: fuse confusion in reply to WaltMo, 04-18-2013 10:43:38
I agree with Walt. You may have voltage to fuse but not the amps to drive pump or blow the fuse. Check up stream.
