distributer points
MrDinWa
New User
Hi all, I purchased a new tune up kit from this site,(points,condenser, rotor,etc.). my problem is the shaft that the points set on seems to corrode quite easily. What is the recommended lube if any to prevent this? It gets so bad that the points won't rock back and forth. This is a front mount 6 volt early 8n.
(quoted from post at 04:18:50 04/18/13) Points lube. If it didn't come with your tune-up kit, you can get it at your auto parts supplier.
My points come from NAPA. They are always in stock; Echlin Brand.
Here are the PN's from the archive, not bad to print out.
Ignition Parts:
Front Mount distributor...
NAPA #CS35
Standard Ignition Blue Streak #FD-6769X (Premium)
Condensor:
NAPA #FA200
Standard Ignition #FD-71
Rotor:
NAPA #FA300
Standard Ignition #FD-104
Distributor Cap:
NAPA #FA350
Standard Ignition #FD-126
Side-Mount Distributor: 8n thru 4 cyl thousand series
NAPA #CS749
NAPA HEAVY DUTY PIERCED (ventilated) #CS753
Standard Ignition #FD-8081
Standard Ignition Blue Streak #FD-8081X (Premium)
Condensor:
NAPA #FA66
Standard Ignition #FD-75
Standard Ignition Blue Streak #FD75X (Premium)
Rotor:
NAPA #FA67
Standard Ignition #FD-108
Distributor Cap:
NAPA #FA352
Standard Ignition #FD-128
Anyways...it comes with lube and says the warranty is void if not used. Any good auto parts store should have it.
