I was installing new points and capacitor in my 8N side mount distributor and broke the copper strip connector that attaches to the point set. As long as I have to replace the copper strip, I thought I may as well replace the primary screw and its insulators. (This is what the single wire attaches to on the distributor body). The tractor is on a hobby farm 50 miles from my house, so I can’t just walk to the barn and take a quick peek at it. Can I replace the primary screw without removing the distributor from the tractor and dismantling it? If I can leave the distributor attached to the tractor, do I have to remove anything from it to get to the primary screw? I would like to leave the distributor attached to the tractor as I am less likely to break anything else while removing it and I don’t want to mess up the timing.
Any suggestions or hints?
