TractorLinks.com
Order Ford 8N Parts Online
Re: Ford 8n 3 point implement will not stay in the up position.
Bill Rowles
04-17-2013 00:48:33
It is best to find the leak by looking through the inspection port on the side of the housing before dis-assembly. You may not fix it if it is a blown gasket or ruptured oil line or leaking relief valve and you only replace the piston seals (which may not be the problem in the first place). If you read through the past year of posts in this forum there are several discussions of the suggested inspection procedure using a light and mirror with the lift operating so oil leaks are visible.
