Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: Ford 8n 3 point implement will not stay in the up position.
Richard Denkha
04-16-2013 18:38:44
If its my hydraulic cylinder, piston rings in order to replace the rings cylinder piston, do I have to pull the PTO shaft out in order to do that? thank you.
JCinKY
04-16-2013 19:00:57
 Re: Ford 8n 3 point implement will not stay in the up positi in reply to Richard Denkha, 04-16-2013 18:38:44
You don't have to remove the pro shaft for cylinder work. Just remover the top cover, can't remember how many bolts but don't remove the 4 most interior nuts that would be between your legs sitting on the seat. They hold the cylinder on.
Top cover is heavy so bring a friend or hoist. Remove the cylinder and a compressed air will fire the piston out. Check the walls, some will hone it if needed.
Richard Denkha
04-16-2013 19:11:23
 Re: Ford 8n 3 point implement will not stay in the up positi in reply to JCinKY, 04-16-2013 19:00:57
thank you for the help.
Copyright © 1997-2015 Yesterday's Tractor Co.
