Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: Ford 8n 3 point implement will not stay in the up position.
Richard Denkha
04-16-2013 18:29:23
at idle it stays up. only when I put it in gear or reverse it goes back down.
soundguy
04-17-2013 05:18:49
 Re: Ford 8n 3 point implement will not stay in the up position. in reply to Richard Denkha, 04-16-2013 18:29:23
it may drop when you step on the clutch to put in gear, as the pto stops. then the idle may be too low to lift it.
time to stop typing and pull that inspection port for a look.
this is an EZ repair usually.
Richard Denkha
04-18-2013 15:30:53
 Re: Ford 8n 3 point implement will not stay in the up position. in reply to soundguy, 04-17-2013 05:18:49
Hi their, I am changing the hydraulic fluid its an all in one fluid transmission and hydraulic. I was thinking can I use regular gear oil in it the one you use for the rear differentials 80W90 on your rear truck axles? its a 1951 ford 8n 4 speed gasoline 4 cylinder. thank you.
soundguy
04-18-2013 15:50:40
 Re: Ford 8n 3 point implement will not stay in the up position. in reply to Richard Denkha, 04-18-2013 15:30:53
not sure why you are telling the machine characteristics as I already know what an 8n is.
if you go with an 80w90 oil.. get one that is rated as MT1 or yellow metal safe. your hydro pump is full of 'yellow metal'
and I would NOT be changing the oil till I found the problem.. as the probalem may make you drop the pump...
you are getting the car before the horse.
Richard Denkha
04-18-2013 18:11:01
 Re: Ford 8n 3 point implement will not stay in the up position. in reply to soundguy, 04-18-2013 15:50:40
I apologize I did not mention this earlier to you, I bought the tractor from my neighbor, he left it out side while rain days where coming. After I bought it and took it home I found out that the hydraulic/transmission fluid is watery at the dip stick then when I drained it it was really watery, so I decided to change it. thank you.
soundguy
04-18-2013 21:23:49
 Re: Ford 8n 3 point implement will not stay in the up position. in reply to Richard Denkha, 04-18-2013 18:11:01
hows the lift acting now?
