Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: Ford 8n 3 point implement will not stay in the up position.
soundguy
04-16-2013 16:38:57
if the leak is significant.. the pump may not be able to keep up with it at idle... etc
Richard Denkha
04-16-2013 21:48:52
 Re: Ford 8n 3 point implement will not stay in the up position. in reply to soundguy, 04-16-2013 16:38:57
Hi their, I wanted to know. On the right side of the 8n tractor where I sit, their is a small lever on the side of the transmission block underneath the seat its not the hydraulic lever or the PTO engagement or disengagement. it is a small lever that can be flipped up or down position its about 4 inches long. What is that used for? thank you.
Richard Denkha
04-16-2013 18:38:44
If its my hydraulic cylinder, piston rings in order to replace the rings cylinder piston, do I have to pull the PTO shaft out in order to do that? thank you.
JCinKY
04-16-2013 19:00:57
 Re: Ford 8n 3 point implement will not stay in the up positi in reply to Richard Denkha, 04-16-2013 18:38:44
You don't have to remove the pro shaft for cylinder work. Just remover the top cover, can't remember how many bolts but don't remove the 4 most interior nuts that would be between your legs sitting on the seat. They hold the cylinder on.
Top cover is heavy so bring a friend or hoist. Remove the cylinder and a compressed air will fire the piston out. Check the walls, some will hone it if needed.
Richard Denkha
04-16-2013 19:11:23
 Re: Ford 8n 3 point implement will not stay in the up positi in reply to JCinKY, 04-16-2013 19:00:57
thank you for the help.
Richard Denkha
04-16-2013 18:29:23
at idle it stays up. only when I put it in gear or reverse it goes back down.
soundguy
04-17-2013 05:18:49
 Re: Ford 8n 3 point implement will not stay in the up position. in reply to Richard Denkha, 04-16-2013 18:29:23
it may drop when you step on the clutch to put in gear, as the pto stops. then the idle may be too low to lift it.
time to stop typing and pull that inspection port for a look.
this is an EZ repair usually.
Richard Denkha
04-18-2013 15:30:53
 Re: Ford 8n 3 point implement will not stay in the up position. in reply to soundguy, 04-17-2013 05:18:49
Hi their, I am changing the hydraulic fluid its an all in one fluid transmission and hydraulic. I was thinking can I use regular gear oil in it the one you use for the rear differentials 80W90 on your rear truck axles? its a 1951 ford 8n 4 speed gasoline 4 cylinder. thank you.
soundguy
04-18-2013 15:50:40
 Re: Ford 8n 3 point implement will not stay in the up position. in reply to Richard Denkha, 04-18-2013 15:30:53
not sure why you are telling the machine characteristics as I already know what an 8n is.
if you go with an 80w90 oil.. get one that is rated as MT1 or yellow metal safe. your hydro pump is full of 'yellow metal'
and I would NOT be changing the oil till I found the problem.. as the probalem may make you drop the pump...
you are getting the car before the horse.
Richard Denkha
04-18-2013 18:11:01
 Re: Ford 8n 3 point implement will not stay in the up position. in reply to soundguy, 04-18-2013 15:50:40
I apologize I did not mention this earlier to you, I bought the tractor from my neighbor, he left it out side while rain days where coming. After I bought it and took it home I found out that the hydraulic/transmission fluid is watery at the dip stick then when I drained it it was really watery, so I decided to change it. thank you.
soundguy
04-18-2013 21:23:49
 Re: Ford 8n 3 point implement will not stay in the up position. in reply to Richard Denkha, 04-18-2013 18:11:01
hows the lift acting now?
