Dacatocham
New User
The solenoid negative cable lug threads on my 8N was stripped, wouldn’t tighten, had to jiggle it sometimes to start the tractor. Finally wouldn"t energize at all so I changed the solenoid with a new 8N11450 from YT. (Small terminal facing the engine). Had a brain fart and cracked the plastic housing on the first replacement solenoid when I tweaked the nut without the backer wrench, tested it anyway – starter turned instantly when I touch the negative battery cable to the battery if I connect the yellow lead from the wire harness to the battery lug on the solenoid. Replaced the solenoid again (without the cracking part). Same thing happens when I touch the cable to the battery. Disconnected the starter switch and same results, starter turns engine when the yellow wire from the (?) ammeter I guess is connected.
In other words, I wire the new plastic solenoid in just like the original steel housed solenoid Henry put on it, and the starter spins when I touch the negative cable to the battery post. I disconnect the wire from the starter switch on the tranny, and the starter still turns when I touch the battery lead.
If I take the yellow wire off of the starter solenoid battery lug,(switch wire disconnected) the starter doesn’t turn when I touch the battery lead. Solenoid clicks when the switch is pushed with the solenoid unmounted from the starter.
I"m guessing short to ground in wire harness, or regulator.
