Working on a 8N that the lower lift pins were loose on. We needed to fix the trumpet seals, so we have taken both off and have removed the loose pins. I have two questions.
First question is the pin that we removed looks like the 8N563 pin, but it looks like the black one is the only one available now as a replacement. Is that correct?
Second question is how do you make sure the hole is not wallowed out like Bruce (VA) has mentioned in a previous post, "Make sure the holes are not wallowed out or you will be in there again. I hear JB Weld works, but I've never had the problem so I can't say for sure."? And can anyone shine some light on the JB Weld process for this application?
Thank,
Hiney
Thank,
Hiney
