Drain plug info
rluscomb
I have a 1950 8N and all but the oil drain plug is missing. Can anyone help me out with part numbers for the other 3 drain plugs? Thanks
Don't forget that those plugs take gaskets. They're available on YT.
I'm pretty sure I used 8N7011 on both of mine not realizing they listed
two different gaskets at the time.
Oil
Hydraulics
Absolutely, roll your own works too. As long as there's one in
there so the plug doesn't get over tightened trying to seal it.
I tore a plug up pretty bad trying to get it out after PO didn't use one.
rluscomb.........while BOTH the engine drain and the tranny drain use the same size gasket, the engine drain plug has a BUILT-IN screen basket that supports the end of the engine oil suck'em-up sheetmetal tube. The flatplate tranny pump does NOT have the screen; and the corner plug is NOT a drain. The diffy has a standard 1/2-in taper'd pipe plug. Use it to drain most of the 5-gals of hydro-tranny oil 'cuz it peeeees innna bucket with some degree of accuracy. ........the plugged-up Dell
