TractorLinks.com
Show Parts for Model:
Re: replace fan belt with front Hyd pump
Dean
04-11-2013 12:03:55
Yes, but removal of the pump drive shaft will likely not provide sufficient clearance to install the new C section belt between the axle and the drive pulley with pump shaft drive attached.
I supported the engine beneath the oil pan, removed the radius arm socket caps and backed out the bolts attaching the axle support to the engine and moved the axle/support assembly forward enough to install the new belt between the axle and pulley.
You will, of course, need to first remove or at least loosen, support and rasie the hood.
Dean
