TractorLinks.com
Order Ford 8N Parts Online
Re: Starter Solenoid Problem 1952 Ford 8N 6 volt Pos Ground
Lowryder
04-11-2013 11:00:39
I had the same problem with a new solenoid, turned out the studs would turn inside the plastic housing causing the problem. I drilled out the rivets holding the base on and moved both studs to the right positions and tightened the nuts, rivited the base back on and hooked everything back up taking care to make sure the studs did not turn. Solved the problem.
