Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: replace fan belt with front Hyd pump
Kirk West
04-11-2013 11:00:00
So I would remove the pump mounting bolts in front of the radiator and it should slide out?
Dean
04-11-2013 12:03:55
 Re: replace fan belt with front Hyd pump in reply to Kirk West, 04-11-2013 11:00:00
Yes, but removal of the pump drive shaft will likely not provide sufficient clearance to install the new C section belt between the axle and the drive pulley with pump shaft drive attached.
I supported the engine beneath the oil pan, removed the radius arm socket caps and backed out the bolts attaching the axle support to the engine and moved the axle/support assembly forward enough to install the new belt between the axle and pulley.
You will, of course, need to first remove or at least loosen, support and rasie the hood.
Dean
old
04-11-2013 11:40:17
In theory yes it should just slide out but I have found on some the hyd hoses are not long enough to let you pull it back enough and if that is the case you have to unbolt the drive at thew pump lift the pump up and then slide the drive shaft out. By the way the belt will be a very tight fit between the drive hub and the axle area. BTDT to many times on my 8N and 841 both have loaders and crank driven hyd pumps
