TractorLinks.com
Show Parts for Model:
Re: Another tractor flip-over story...
CJ in Michigan
04-11-2013 07:35:32
I believe he was attempting to remove a stump with a TO-30.
Jimps
04-11-2013 08:54:34
 Re: Another tractor flip-over story... in reply to CJ in Michigan, 04-11-2013 07:35:32
From the original story from KGW.com:
"Jeff Smith was pulling a stump from his garden near McDowell Creek Park on Monday, but his mud-caked boot slipped off the tractor’s clutch. The machine flipped upside down and on top of him."
Jimps in GA.
Bill Rowles
04-11-2013 07:54:23
I was taught to always connect the tractor to anything you are planning to pull (chain, rope, or implement)at the draw bar or other connecting point located between the center-line of the rear axle and the ground surface. This rule, when followed, will prevent the over-turn action during a pull. I believe we will probably find this rule was violated by the tractor operator in this accident.
CJ in Michigan
04-11-2013 08:18:50
 Re: Another tractor flip-over story... in reply to Bill Rowles, 04-11-2013 07:54:23
Found a link-
8N-Bob
04-11-2013 08:39:46
 Re: Another tractor flip-over story... in reply to CJ in Michigan, 04-11-2013 08:18:50
I was always told to pull stuff like that in reverse so the tractor does not filp. Pulling from the rear if the tractor stops the rear wheels keep on moving forward and next thing the front raises off the ground Keep on going and you are upside down.
Bill Rowles
04-11-2013 08:51:49
 Re: Another tractor flip-over story... in reply to 8N-Bob, 04-11-2013 08:39:46
If you hook to the rear of the tractor below the center-line of the rear axle, I believe the wheels will spin before tractor will over-turn. It should be noted however that the rear wheel(s) must be "free-to-spin" (not tied or chained to something immoveable such as the ground or a railroad track.
8N-Bob
04-11-2013 08:54:23
 Re: Another tractor flip-over story... in reply to Bill Rowles, 04-11-2013 08:51:49
All I know is that my Rears are filled with fluid and when I plowing and go to deep and hit something the front end starts a raising.
Bill Rowles
04-11-2013 11:08:02
 Re: Another tractor flip-over story... in reply to 8N-Bob, 04-11-2013 08:54:23
The front gets "lighter" for two reasonswhen plowing, the hydraulic lift pulls upward on the plow (manual or automatic draft action) and the tractor is pulling on the plow.......however, the tractor will not over-turn when pulling the plow or other implement because of the location of the attachment being on the trumpets and below the axle.
