TractorLinks.com
Order Ford 8N Parts Online
Re: Starter Solenoid Problem 1952 Ford 8N 6 volt Pos Ground
JMOR
04-11-2013 07:31:05
"If I take the yellow wire off of the starter solenoid battery lug,(switch wire disconnected) the starter doesn’t turn when I touch the battery lead.".....that right there says that you have some very incorrect wiring on your tractor!! Whether or not that yellow (power to everything else) wire is connected or left hanging in the air will make absolutely ZERO difference to the solenoid/starter operation on a correctly wired tractor!! I suggest you verify wiring against correct FO-4 diagram or one of my diagrams, if you find friendlier to work with.
