Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: Starter Solenoid Problem 1952 Ford 8N 6 volt Pos Ground
Dean
04-11-2013 06:46:08
It"s not the voltage regulator but it could well be a short to ground somewhere between the starter switch and solenoid.
Dean
Dacatocham
04-11-2013 08:20:19
 Re: Starter Solenoid Problem 1952 Ford 8N 6 volt Pos Ground in reply to Dean, 04-11-2013 06:46:08
Thanks guys. I have to evict a bunch of field mice from my tractor each spring. Dang gnawers. I have a new wire harness I am going to install as soon as the mud from this rain and ice storm dries up enough to drive back in there.
Dacatocham
04-12-2013 12:04:56
 Re: Starter Solenoid Problem 1952 Ford 8N 6 volt Pos Ground in reply to Dacatocham, 04-11-2013 08:20:19
It's still too muddy to visit my N, and I was bored, so I disassembled the cracked solenoid from YT. I guess no-one explained the theory of electricity to the guy building solenoids in some Chinese factory. The slack in the copper wire they wrap around the copper lug when they assemble the solenoid was left in an upright loop satisfying the contactor. Back together and bench tested. Continuity between the big neg battery stud and the little ignition switch stud, none to the big starter side lug. Then I apply 6 volt negative lead from my battery charger to the big ignition stud and attach the positive charger lead to the small switch lug on the side of the solenoid, the relay clicks and holds the contact establishing continuity between the big ignition lug and the big starter lug. Does that seem right?
JMOR
04-12-2013 12:12:03
 Re: Starter Solenoid Problem 1952 Ford 8N 6 volt Pos Ground in reply to Dacatocham, 04-12-2013 12:04:56
Terminology a bit awkward, but yes, power from batt (lrg) to small (start) energizes, but no energize with opposite large terminal & small.
Copyright © 1997-2015 Yesterday's Tractor Co.
