TractorLinks.com
Show Parts for Model:
Re: Starter Ring
nebken
04-09-2013 19:18:34
I chnged mine a few years back. The gear set down in a groove. I had to heat it and press it off. When it came off the gear was all bent and twisted. You you put it back on, you will have to heat it very hot and then spray water on it to get it too shrink tight on the flywheel.
I have changed several case and farmall gears. My 9n was the hardest one to change.
36 coupe
04-10-2013 07:05:06
 Re: Starter Ring in reply to nebken, 04-09-2013 19:18:34
Do not put water on a hot ring gear.Cooling it fast will stop the shrinking process.You will end up with a loose ring gear.
