TractorLinks.com
Show Parts for Model:
Re: pto shaft won't slide back in?
gwstang
04-09-2013 17:08:07
Today, I did drain the tranny oil and loosen the pump bolts (lots of those things) and it would still not go in properly. I whacked it with a hammer a few times and it went in...but, I could not get the pto out of gear. It would turn when the pto lever was up or down. I ordered a new shaft and will pick it up tomorrow (conversion type) and maybe that will slide right in?
soundguy
04-09-2013 18:11:39
 Re: pto shaft won't slide back in? in reply to gwstang, 04-09-2013 17:08:07
were the interior splines twistd? a common issue..
gwstang
04-09-2013 18:50:35
 Re: pto shaft won't slide back in? in reply to soundguy, 04-09-2013 18:11:39
They did not appear to be. It did slide right out originally when I removed it. I'll try the new one tomorrow evening and see how that works and get back to ya'll.
soundguy
04-10-2013 04:43:43
 Re: pto shaft won't slide back in? in reply to gwstang, 04-09-2013 18:50:35
sometimes it don't take much twist to stop one. and.. the twist might have been 'custom' fit' tothe coupler and when you put it back in you didn't get the magic spline placement inthe same 'slot' :)
so if the new one don't fit.. take the old and try it turned 1 spline at a time to see if you find one spot that magically engages ok.
gwstang
04-10-2013 16:15:51
 Re: pto shaft won't slide back in? in reply to soundguy, 04-10-2013 04:43:43
It must have been a twist. I picked up the new one this afternoon and it slid right in! All is well now. Thanks for everyone's help. I do have one small problem. The pto stub is now the larger size and my over run coupler is for the smaller size. Is there a sleeve that will will convert the larger stub to fit inside my orc now?
JMOR
04-10-2013 16:34:26
 Re: pto shaft won't slide back in? in reply to gwstang, 04-10-2013 16:15:51
Quoting Removed, click Modern View to seeThings get awfully sloppy when you add more parts to all that rotates there. Sometimes the added adapter length results in need to cut bush hog drive shaft, too. Been down that road, & advise new ORC. I leave adapters to the baling wire crowd.
gwstang
04-10-2013 18:25:48
 Re: pto shaft won't slide back in? in reply to JMOR, 04-10-2013 16:34:26
I am thinking that is a better idea too, I'll just bite the bullet and buy a new one before I have to bush hog this spring. Thanks, Gary
soundguy
04-11-2013 05:13:13
 Re: pto shaft won't slide back in? in reply to gwstang, 04-10-2013 18:25:48
ditto.. get the new orc!
