TractorLinks.com
Show Parts for Model:
Re: Help ID Carb
JCinKY
04-09-2013 12:47:35
Sounds good. It had the weird wire clip (???) on the float needle and float, but was basically spotless on the inside. The last complete kit I got at TSC was actually pretty good.
Yes, it was on a 52 8n. Thanks for the help on the VREG too.
old
04-09-2013 15:00:53
 Re: Help ID Carb in reply to JCinKY, 04-09-2013 12:47:35
That wire clip as you call it is so the float needle cannot stick closed in theory so if the float falls it in turn pulls the needle down and makes sure it opens so gas can flow in
soundguy
04-09-2013 12:58:23
for the most part.. them repop carbs work just the same.
I've used a couple on some stuff at work. I kludged one up to an old cintinental / red seal power unit at work with a lil dremel work onthe manifold ears.
works just fine.. :)
