Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Help ID Carb
soundguy
04-09-2013 10:49:43
looks like one of the 2 most common ms repops.
some are CI some are a alloy metal with bright coating... I prefer those LESS as they flake and get powdery corrosion on them.,.
most of the repops i see rebuild with MS kits..
JCinKY
04-09-2013 12:16:48
 Re: Help ID Carb in reply to soundguy, 04-09-2013 10:49:43
It did have some original MS parts inside; float, throttle plate, choke plate assembly. Everything else was aftermarket.
I just about have the front mount/side mount engine swap done. I will give her a good cleaning, throw it on the "parts" tractor and see what she'll do.
Not planning on buying a kit just yet, just needed some direction in case I do.
Thanks
soundguy
04-09-2013 12:44:31
 Re: Help ID Carb in reply to JCinKY, 04-09-2013 12:16:48
unless they have changed them recently inthe last couple years.. last one I rebuilt used the generic ms rebuild kit from tsc and worked fine.
who knows what they come with now.. :)
JCinKY
04-09-2013 12:47:35
 Re: Help ID Carb in reply to soundguy, 04-09-2013 12:44:31
Sounds good. It had the weird wire clip (???) on the float needle and float, but was basically spotless on the inside. The last complete kit I got at TSC was actually pretty good.
Yes, it was on a 52 8n. Thanks for the help on the VREG too.
old
04-09-2013 15:00:53
 Re: Help ID Carb in reply to JCinKY, 04-09-2013 12:47:35
That wire clip as you call it is so the float needle cannot stick closed in theory so if the float falls it in turn pulls the needle down and makes sure it opens so gas can flow in
soundguy
04-09-2013 12:58:23
for the most part.. them repop carbs work just the same.
I've used a couple on some stuff at work. I kludged one up to an old cintinental / red seal power unit at work with a lil dremel work onthe manifold ears.
works just fine.. :)
